@mjdean we will need to know the exact model for your dishwasher. The F6 E6 (model dependent)is a water temp code that means the incoming water from the house is too cold. It is also possible that it does not detect any incoming water despite the water inlet valve being open. Try and check if this will work for your specific model:
Diagnostics Cycle, perform the following while in standby:
■ Press any 3 keys in the sequence 1-2-3-1-2-3- 1-2-3 with no more than 1 second between keys.
■ The Service Diagnostics Cycle will start when the door is closed.
■ To rapid advance 1 interval at a time, press the Start/Resume key. Rapid advancing may skip sensor checks as some checks require 2 complete intervals.
NOTE: While in the Diagnostic Cycle, the Start/ Resume feature is turned off (for example, Auto Resume after door interrupts) and the Start/Resume key becomes an interval advance key.
■ Invoking Service Diagnostics clears all status and last run information from memory and restores defaults. It also forces the next cycle to be a sensor calibration cycle.
■ Last run cycles and options returned to default (Normal cycle with Heated Dry option).
■ Last run delay returns to the lowest delay increment.
■ Calibration cycle may force an extra rinse to occur prior to Final Rinse (to assure clear water), then calibrates the OWI and the fill amount during the final rinse.
■ Operating state returns to Standby upon completing or terminating the Service Diagnostics Cycle
4 comentários
Hi I have the same problem error f6 on a whirlpool 6th sense dishwasher. Would appreciate any help
por Louise Doherty
I have problem in My whirlpool dishwasher.
Type: WASFS
NOT WORKING
GIVE ME E6 and EC
HOW CAN I FIX IT ?
por Bander Algrni
Hello I have this problem as well. I have the whirlpool dishwasher model wdf760sadb0. Ran the diagnostic and f6 e6 where the codes that came up.
por frank
I have the same error codes as listed in original post (E6F6 as well as E-F-). Mine is a Whirlpool WDF760SADM0. what prompted me to run the diagnostic mode is that the spray arms are not consistently spraying. Sometimes it works fine and washes the dishes, other times it only fills with water, then makes some clicking noises (as if trying to engage the spray arms but can't) and then it drains.
por Jonathan Winkelman
