Ir para o conteúdo principal
A high end, advanced point-and-shoot camera manufactured by Canon.
Camera got wet doesn't power up
I have a Canon SX50 HS or should I say I did have.
Stupidly, I left it out in the rain one night, got distracted by the kids.
Worked ok for a few weeks and then decided to give up the ghost.
Now it will not turn on.
I tried replacing the external battery, no luck.
I read on this site that cameras have an internal battery.
Does the Canon SX50 HS have an internal battery?
This happened a few months ago now and still doesn’t power up. So I suspect it will be dry inside now but some type of damage has been done.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
William Jackson  dry maybe but also corroded. you will have to disassemble Canon PowerShot SX50 HS your camera and clean it properly. Use some 90%+ isopropyl alcohol and a soft brush then clean all the parts with it.
This should help you out aswell
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
William Jackson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 30
Ao todo: 591
