Ir para o conteúdo principal
Guias de reparo e suporte para a terceira geração do Ranger, uma picape compacta fabricada pela Ford.
Rough idling, rough running, loss of power, poor fuel economy
Truck idles rough after start and continues to do so while driving. Bad vibration. Loss of power, hard to maintain highway speed. Very poor gas mileage.
My attempted fixes have been.
  1. New fuel filter
  2. New spark plugs
  3. New plug wires
  4. New timing belt
  5. New serpentine belt
  6. Tried Sea Foam system cleaner
  7. Tried Chevron fuel system cleaner
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
@bangbangtrs
this could be lots of things from a bad MAF, bad crankshaft position sensor to a cam positions sensor and many things in between. I would suggest that you get the OBD scanned and see what codes your truck shows. At least then you have a starting point. You also want to let us know the exact year and engine size for your truck.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Thanks so much for responding so quickly. I was in such a rush I completely forgot to add engine and year. It's a 1999 Ford Ranger XLT regular cab 2wd with the 2.5 liter 4 cylinder. Funny thing is that the check engine light is not on. Can I still use an OBD if it's not lit? Thanks again.
por
Yes you can. Not every code trips the check engine light.
por
Adicionar a sua resposta
Todd Soderbeck será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 29
Ao todo: 744
