Ir para o conteúdo principal
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Perguntas Visualizar todos
Will not power on after changing the charging port
I had to change my charging port in my IPhone 7 Plus. Afterwards, it wouldn’t power on. Please someone help!!!!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Retrace your steps to determine if it’s the charger port or if something was simply misaligned. Pull up the guide again and make sure everything is in place and no debris is affecting it’s charging ability.
Esta resposta foi útil?
Pontuação 1
The iPhone 7 plus is very easily misaligned and either not connected or the connector itself can be damaged due to this misalignment. Step one is to test the phone with a known good battery that has at least enough charge on it to power the phone on. If it doesn’t power on with a good battery, it is likely board level. There are also a few test points on the board you can test with a multimeter to see if you are getting power through the charge port and at least to the connector.
Pontuação 1
Adicionar a sua resposta
Susan Colby será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 43
