Ir para o conteúdo principal
The first generation (KJ) Jeep Liberty, a compact 4-door SUV. Sold in both 2WD and 4WD configurations.
Why did my horn randomly start going off?
06 jeep liberty. Randomly horn started going off so I had the horn unplugged. I took it to get looked at and they said horn switch and they'd have to replace whole steering wheel (or add a button in the dash for less $$). Is it common to replace whole steering wheel?
Esta é uma boa pergunta?
Pontuação 0
6 comentários
i just got it fixed 2 x's and my mechanic said i needed a new battery that was 2 wkkks ago and again it happened. Now he said i needed a new ignition was damaged. I need guidance. I so nervous the horn will go off again.
por
Wow! 1st reply from so long ago. I don't even that that car anymore. But in my case I just took the fuse out but my windows were connected to same fuse. So I got a family friend to unhook the horn and put the fuse back in. Went on like that for a few days then took it to a shop that said a whole bunch was wrong and I couldn't afford it and left. Then went back to my family friend to reconnect and see if he could fix it... but when he reconnected it it didn't come on continuously. I left horn unhooked for a few weeks. I think mine was just the wiring or something. Didn't do it again and then I traded it in. Find out which fuse it is in your car tho just so you can pull it out if you need to. It'll drain your battery and get you a lot of stares.
por
1 person said horn switch or horn relay.. always get 2nd or 3rd opinions
por
@mceravo sounds like BS to me. your ignition itself would not set of your horn. Pulling the fuse will only interrupt the power but not fix it. Replace your horn relay first. If that does not work it is possible that this is caused by the horn button in your steering wheel (or the clockspring (has nothing to do with the clock:-)))
por
It's a major problem on jeeps of that year and some others. It's because of the way they are wired. The fuse box is not like others. The horn has no fuse its wires to lots of stuff. The best way I have found to fix is to run a jump wire to the horn from the battery.
por
Exibir mais 1 comentário
Adicionar um comentário
2 respostas
Solução escolhida
@jillanne
I would suggest that you replace the horn relay first. The steering wheel does not need to be replaced but the button is molded in the Air bag assembly (what a stupid idea). Go with an external button somewhere else and safe yourself a boatload of money (if it is the switch and not the relay)
Esta resposta foi útil?
Pontuação 3
6 comentários:
I cant get fix till next week but sound is very annoying
Can i get the fuse out?
por
2009 Jeep Compass does the same thing. I unplugged my horn. My belief is there is corrosion or a short. Probably bad relay.
What up Old Turkey !!! Seen ya in SLO !
This man is legend !
por
@tonytone No corrosion in southern California :-) I go with a bad relay as well.
Doing well of course and I hope you are too.
por
Definitely. I asked Kyle to throw another one years ago and he said ya. Hasn't happened yet. LOL. I believe the relays are the same and you can swap them to test. But mine is really random. Only happens when it rains or high-humidity. Is 86% today. So it going to be hard to diagnose. But I may just replace it to see. I could not find a fuse to pull. Will have to locate the relays, but think I know where they may be at.
por
@tonytone that would be great. Time we all get together and sit down for some IPA's
GEt the SM for your Jeep from here Should have all the info you need to keep your Jeep honking and going.
CAN Bus? TIPM? No relay? Chrysler and their TIPM. There are always issues with that.
por
The sound of the clicking is very annoying can I take out the fuse off the horn until I get it fixed next week?
Pontuação 0
Adicionar a sua resposta
Jillanne Cox será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 76
Ao todo: 17,392
