Spin cycle only spins after I lift and re-close door
My top-loaded Kenmore washing machine won’t spin on the spin cycle unless I open the door at the start of the spin cycle. It sounds like it’s spinning, but nothing happens until I lift the lid (which stops the motor), and then re-close the door (which then starts the spinning). Since the spin function works when I re-close the door, I have a hard time thinking it’s the coupler or pressure switch. Also, since the motor runs without intervention, I don’t think it’s the lid switch
Any ideas???
Esta é uma boa pergunta?
13 comentários
Thanks @oldturkey03 ! I’ve seen some YouTube clips of people fixing the lid switch with a zip tie. Would you recommend this method, or buying a replacement lid switch?
por Kenny Coleman
@kenneo1 for now it's okay to try the Zip Tie idea. See if it works.
por oldturkey03
@oldturkey03 just replaced the lid switch - same issue
por Kenny Coleman
@kenneo1 okay. Let us know the exact model number for your washer. We may find a schematic to see what else could be causing this. Definitely strange.....
por oldturkey03
@oldturkey03 110.88752793
por Kenny Coleman
Exibir mais 8 comentários
