Have a white screen on power up
Moniter was on and all of a sudden went white. Now it is always white no matter what I do. Is it a motherboard issue or something else?
Esta é uma boa pergunta?
White screens are usually indicative of a bad hard drive or corrupted boot system.
Esta resposta foi útil?
mrbruce300 on your monitor this just means that only your backlight is on. You will have to check the video source and see if it is connected etc. If the monitor does not show a menu etc. on startup when disconnected from a video source you most likely have a bad main board.
These monitor had issues with bad caps, so you will have to take a look at the boards and check for an obvious damage. Post some images of the boards with your question so that we can see what you see. Adicionar imagens a uma pergunta já existente
Here are the disassembly instructions disassembly.pdf
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 111
