Ir para o conteúdo principal
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
MacBook Pro SSD Upgrade - will it affect speed?
Hi, I have a Macbook Pro Retina MId 2015 250 GB and I’d like to upgrade my SSD to 480 GB or even 960 GB.
I checked several options for a replacement (i.e. Transcend Jetdrive 820 or the most recent 850) but I am worried that disk write and read speeds will be negatively affected. With the Apple SSD my Macbook scores 1033 MB/s and 1950 MB/s at the Blackmagic Disk Speed Test.
These speeds seem not even be supported by the aforementioned SSDs (up to 950 for the 820 and up to 1300 for the 850), but I am not sure if these measurements should actually be compared with each other.
Thank you in advance for any advice you can provide on the matter, especially if you have some personal experience with such an upgrade
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Another option is just getting a larger Apple drive while more expensive it will give you the same if not better I/O speed. Here’s a useful guide The Ultimate Guide to Apple’s Proprietary SSDs as an example SSPOLARIS 512 GB SSD
Esta resposta foi útil?
Pontuação 3
2 comentários:
Thank you for your answer. I didn’t know there were OEM Apple SSDs out there for sale. It’s certainly not cheap, but the biggest issue is that I am not in the US and I am not sure these products are available on the local market (Europe).
But thanks anyway. I will do some additional search to check if they are available.
Let’s see if somebody has some direct experience with third-party SSDs to share.
por
I would try TheBookYark in the UK SSD Options
por
I had a terrible experience trying to use an OWC 512 GB SSD - the one they recommended, but they were pretty cage-y.
It was 0.1 mm thicker than the OE SSD, and required unusually high force to insert, which twice caused a motherboard failure.
OWC: "it meets the Apple spec"; not our problem. I counted it a tough learning experience.
I sprung for a used OE Apple 512 and have never been sorry.
My biggest regret was learning that OWC would not back up its product warranty. Now wary of everything they sell.
Pontuação 0
5 comentários:
I find that hard to believe! I've put in more than 100 OWC drives in many different Mac's and haven't encountered any issues. The only drives I've had issues with are people using M.2 drives with an adapter. I've pulled out a ton of them often replacing with either an Apple or OWC blade drive.
por
Hey Dan, I wish you had been in my shoes! Not to wish on you the same problem I had, but to hear how you handled the experience, if you tried installing that particular SSD in an MBP mid-2015.
I certainly did not expect something like this, or to be treated the way they did. I bought many, many HW items, HDs, SSDs, and even computers from them over many years, without issue.
It still hurts to think that if I want a new drive or some other hardware, I pretty much have to go to OWC. How can I be sure if there's a problem, they'll live up to the 'warranty'. It really soured my on them. Once bitten, twice shy.
I also wondered about who was going to next receive it. I hope that on some Monday morning, when they knew they didn't have to come clean to me, that they decided it was in fact defective.
por
@prreitz - what is your exact model and which OWC drive did you use? They did have some issues in the first gen drives and some people tried using them in the newer models.
por
Dan, sorry it's taken so long. (Took another failure to bring me back here.)
After the second motherboard failure I replaced the failed 2.2 GHz with a used 2.5 GHz (11,5) version.
The SSD was what OWC provided as correct for my computer. They had all the info, all I could do was take their word for it. In retrospect, I'm convinced the results indicate it was not the right one. I had read elsewhere that there were several subtle iterations in the SSDs used in this model MBP (mid-2015) that made it difficult to know what would actually work.
Since my original goal was to increase storage from 256 to 512 GB, I bought a used Apple 512 removed from another mid-2015 MBP. And it mated perfectly— snug, but only modest force to seat. After it was over, I measured the OWC SSD board to be 100 µm thicker, which would make a tighter fit. It had a profound effect in this case.
Anyone can make a mistake, but it was the stiff-arm from OWC that was most disappointing. To settle, they refunded my money. All-in, it cost ~ $1,000 for board replacement and 512 GB SSB. I took that route because I was unwilling to risk a 3rd motherboard failure (they insisted, without further detail that it "met Apple specifications!), and they were unwilling to do the installation to experience it for themselves.
In answer to your question, here's the System Information with the replacement motherboard:
Model Name: MacBook Pro
  Model Identifier: MacBookPro11,5
  Processor Name: Quad-Core Intel Core i7
  Processor Speed: 2.5 GHz
....etc.
  Memory: 16 GB
  System Firmware Version: 476.0.0.0.0
  OS Loader Version: 540.120.3~22
  SMC Version (system): 2.30f2
  Serial number xxxxxxxx
por
FYI - I have two of these which I use in the field when shooting (one is a backup) both have the OWC 1TB SSDs! Not a lick of trouble!
I can’t explain what happened here, OWC has been selling these drives for awhile. The PCB thickness does drift a bit in the manufacturing process. A 100 µm difference is quite small, but it’s on the edge of the tolerance window I would expect. For reference review the M.2 physical board standards as you can see there it’s not excessive. That’s not Apples spec as I don’t have access to that but it’s basically the same.
While you won’t want to hear this, I have encountered logic boards damaged by people lifting/inserting the drive at to sharp an angle causing the socket to become damaged. I think I’ve replaced three or four across a few different series over the years.
por
Adicionar a sua resposta
Thelonious Monk será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 779
