Ir para o conteúdo principal
The Asus VivoBook Q200E-BSI3T08 touchscreen laptop was manufactured by Asus in 2012.
Help fix laptop been a year since it broke. Pls help!
When I open the laptop it has green horizontal lines which then fade away into white vertical lines. But after I restart it, the laptop goes into a blue screen that keeps coming back no matter what options I chose in troubleshoot.
Esta é uma boa pergunta?
Pontuação 0
3 comentários:
Hi,
Try connecting an external monitor to the laptop and check what its' display is like.
por
Laptop is blue screen coming
por
My laptop blue colour coming
=== Update (10/25/23) ===
Blue screen coming laptop
por
Adicionar um comentário
1 resposta
hi, if you have acces to the RAM memory get a eraser and slide it from the edge that connects to the computer, if you have more than one RAM clean all of it and try it one by one, your problem can be a memory malfunction, good luck
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Ender 33 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 140
