Ir para o conteúdo principal
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
596 Perguntas Visualizar todos
Dead Backlight on MacBook Pro Screen 15 inch Mid 2012
Hey everyone,
Unfortunately, the backlight on my Macbook Pro has died. After some research, I think the culprit is a burnt fuse. I stupidly set down my laptop on what I later realized was a wet surface (it wasn't soaking wet or anything, but apparently wet enough). The display suddenly went black after a few minutes and hasn't turned back on, even after SMC/PRAM resets.
I tried plugging in an external monitor, and sure enough, it works fine. I took a flashlight and shone it on the dead display. I can see everything, leading me to believe it is indeed the screen backlight that's the issue.
I did a lot of research, but I can't really find any answers on how to go about diagnosing the exact issue and going on to fix it. Does anyone know roughly how much a Genius bar repair would cost? Is it even worth it? My laptop will be 5 years old in a few months, and has a lot of other issues as well (like a dead keyboard that I'm using a bluetooth keyboard to get around and a battery that needs replacing). On the other hand, I did just invest several hundred dollars into other repairs in the last year like a new SSD and new chargers, so if I'd be happy if I don't have to write it off.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Well, you’ve done an excellent initial troubleshooting and it seems indeed a backlight issue. Forget about Apple support, even if it was just the fuse they would replace the entire logic board bringing overall costs to be not worth the repair. Further troubleshooting depends very much on your readiness to invest time and money on it..it might be as simple as the fuse itself as well as it might be the BL driver and related components. If you have around somebody reputable into Apple boards component level repair it would be the easiest way, but if you feel like it you can have a try yourself.
Esta resposta foi útil?
Pontuação 2
2 comentários:
@arbaman Thanks for the advice. I was thinking the same about Apple, but I don’t have any authorized apple tech support around me and I’d hate to take it to someone unfamiliar with the mac system and end up with a more expensive mess.
I wouldn’t mind having a go at it myself. Even if I’m able to troubleshoot it myself and then take it to someone with soldering experience (which I imagine you need to replace the fuse) and give them the exact location and replacement fuse, that would work pretty well. Trouble is I have no idea how to begin troubleshooting, so if you could point me in the right direction I’d appreciate it. (I even tried finding the fuse a few times but mine must not have a P printed on it because I can’t find it anywhere)
por
Would need the board number to be able to point you exactly to the fuse..I don' t remember having worked on a board like yours. However, if it's the same layout as the previous releases, you might not see it as it's located on bottom side right under the loudspeaker. Fuse you would need is F9700, a 3 AMP-32V-467 such as these: www.littelfuse.com/~/media/electronics/datasheets/fuses/littelfuse_fuse_467_datasheet.pdf.pdf
por
Adicionar a sua resposta
Luke será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 15
Duração total: 1,096
