Ir para o conteúdo principal
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
254 Perguntas Visualizar todos
How do I know the exact logic board to buy?
went to repair my imac but they are charging me $1000 for the repair. Im seeing online to buy the logic board myself. How do i know the exact part number for the logic board
model a1418 emc 2638
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
@nacordiaz according to the information you are giving us, yours is an iMac14,3 Late 2013. Take a look at the board itself. There might be a 820-XXXX number on it. That is the number you want to use for an online search. You model uses amongst others a 820-3588-A board which is a 2.7GHz Core i5 with integrated CPU It has a non-removable CPU and GPU. Apple part number for that is 661-7923. Other boards for your iMac are a 2.9GHz (Apple part number 661-7503)and a 3.1GHz and have a removable CPU option.
With those numbers you can most certainly match the board in your iMac and purchase wherever you would like. There are great places like this one and many more. It’ll depend on where you are located at and whatever seller you are comfortable with.
Esta resposta foi útil?
Pontuação 3
Here’s a good source TheBookYard UK logicboard offerings for your iMac they also post the Apple P/N’s so you can look at other options which might be closer to you.
Pontuação 2
Adicionar a sua resposta
Nacor Diaz será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 442
