Ir para o conteúdo principal
Repair and troubleshooting information for the ASUS Flip C100P Chromebook. Released in 2012.
Cracked screen making it hard to use.
I have a pretty big crack in my screen....no dead pixels, but it's making the touch screen go crazy. I can hardly use the chromebook even in laptop mode because the screen will flicker and open random things as if someone is going crazy on the touchscreen.
I looked into ordering the screen repair kit but found it was almost as expensive as a new chromebook. So my question is, is there a way I can just disable the touchscreen function? I don't mind only using it in laptop mode.
Thank you
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
steph fxe this should work for you
First go here: chrome://flags/#ash-debug-shortcuts and enable the flag, then click RESTART NOW at the bottom of that page.
Once that's done, you have two new keyboard shortcut toggles available to you -
Toggle touch screen on/off: --> Search+Shift+T Toggle touchpad on/off: --> Search+Shift+P
WARNING - use of this feature may cause unwary users to think their touchpad or touchscreen is defective. There are no status indicators to tell you that you have turned the touch device off!
Esta resposta foi útil?
Pontuação 4
2 comentários:
Alright! thanks so much, I never would have figured that out by myself. You just saved me a bunch of money, awesome.
por
Thank you so much! Same problem, thought I would have to buy a whole new computer since repairs are hardly a different price.
Mine is a chrome pixelbook and just a tiny crack in the bottom left of the screen but caused massive glitching. Again, tysm!!
por
Adicionar a sua resposta
steph fxe será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 2,311
