Ir para o conteúdo principal
Décima geração do SUV de porte grande da Chevrolet, baseado na plataforma GMT900 da GM.
Brake light issue 09 Suburban
I have a 2009 Suburban. I noticed the passenger brake light not working so I changed the bulb but in the process, noticed the brake lights didn’t work with the truck off. I put the key in the ignition and turned it over, then the brake lights worked. What could be the issue causing them to not work unless the truck is on?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Brake lights on some vehicles just do not work with the ignition off. I believe this is a feature to save the battery in case there is a fault in the brake system, but I do not know. My car’s brake lights do not turn on when I have the key off either.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Lisa Snodgrass será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 19
Ao todo: 602
