Ir para o conteúdo principal
O smartphone LG Leon LTE foi projetado e fabricado pela LG Electronics, e vem com um aplicativo de hotspot para compartilhamento de internet e muitos outros aplicativos Android.
How to correct this defect
''Is there a way to fix this device that's not charging and the display screen shows the start up screen that is looping? My device shows that the battery
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I had that happen on a Droid Turbo 2 repair. Turned out, the owner had splattered soda on the phone and the keys were sticking down. The phone was looping because the power and volume down keys were stuck down. I used a soft art paintbrush and alcohol to clean the stick out. Don't wet the board and keys to much. Just a little at a time should do the job. If that doesn't work, you might have to do a tear down and remove the buttons from the device. Do be careful and always use a strainer in the sink so you don't have to order new keys.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
DJ PROPAGANDA será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 252
