Ir para o conteúdo principal
O Western Digital My Passport Ultra é um dispositivo de armazenamento portátil USB 3.0 com capacidades de 500 GB até 5 TB.
Replacing hard disk reading heads
Hi there!
I have broken reading heads on my WD10JMVW-11AJGS0. Which model can suit with same reading heads to replace? Didnt find this model on amazon/ebay so im trying to solve by this way. Thank you very much!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
If you haven’t taken your drive apart STOP!
HDD’s are not something you can work on in a dust filled room! Even still this is beyond what an DIY’er can even attempt!
If you’ve already opened the drive you’ve likely killed it! Between the dust and finger prints as well as and moving the parts around you’ve likely damaged it beyond repair.
If the data is important to salvage you’ll need to send the drive out to a clean room and people who have the needed parts, like DriveSavers. Take a watch here on YOUTUBE: DriveSavers Recovery Tour
Esta resposta foi útil?
Pontuação 1
2 comentários:
I'm sorry, but dont have 2,500€ for this type of repair. I questioned about head compatibility. Thank you
por
Then it would be cheaper to get a new drive and forget what ever was on it.
por
Adicionar a sua resposta
Lukáš Blažek será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 23
Ao todo: 1,981
