Ir para o conteúdo principal
Modelo A1419 / EMC 3070 / Meados de 2017 / Processador Kaby Lake Core i5 de 3,4, 3,5 ou 3,8 GHz ou Core i7 de 4,2 GHz (ID iMac18,3) / Tela Retina 5K. Consulte os guias do iMac Intel 27" com tela Retina 5K (final de 2014 e 2015) mais antigos, pois o sistema é muito semelhante.
CPU Upgrade to 8th Gen Intel
Hello Guys!
Last year I bought a base model iMac 5K and it was working fine for me but my work has intensify and I would like to upgrade the CPU to an i7 and the HDD to and SSD .
My question is: Now that Apple lunched the Eight Gen CPU's in the new Macbook Pro. Can I opt for the 8700K(or any variant of it) instead of the 7700K?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
3 respostas
Solução escolhida
Sorry not an option in your system the rest of the systems logic would need to be swapped out as well (which is not practical) your system is based on Kaby Lake the new 8th gen is using Coffee Lake architecture while similar it’s not drop in compatible.
Esta resposta foi útil?
Pontuação 2
hi Alex Castro your imac only upgare to high cpu but only same life and socket
Pontuação 0
This is possible,It has been done on motherboards from third party vendors, apples logic is no different, What is needed is a patch for the bootloader, or a spoof in the efi and the compatibility fix added to it that was done with z170 motherboards.Whoever does it first will get a ton of rep.For now though if you can get a 7700k, you wont be disappointing, And I wouldn’t hold your breath on anyone in the mac community putting as much trial & error and time into this.(Just saw that its quite a few months old, didnt mean to revive the dead thread).I also swapped in a 7700k from an i5, tricky but rewarding.
Pontuação 0
1 comentário:
Yes its easy on a Windows PC, Mac's are a very different beast! Its just not that easy. Unless you've got the skills to dig deep into the firmware its just not possible!
por
Adicionar a sua resposta
Alex Castro será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 26
Ao todo: 3,796
