Ir para o conteúdo principal
Gateway laptop with 4 GB RAM and 500 GB HDD. Model number: NE56R49u.
Laptop is messed up
What to do if charger port is messed up and lifting up the screen makes the keyboard lift up.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
mr_mrs031710  for the charging port you would need to repalce the compelte power jack connector with something like this
This “lifting up the screen makes the keyboard lift up “ sounds like a bad hinge. We would need to see more of the hinges. Take some good pictures and post those with your question. thyat way we can see what you see. Use this guide Adicionar imagens a uma pergunta já existente for that. This video ill help you with the power jack., and this one for the rest of the disassembly.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
mr_mrs031710 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 242
