Ir para o conteúdo principal
Um laptop de 11,6” projetado para oferecer valor, o Chromebook 100S possui uma tela de 1366 x 768 e até 8 horas de autonomia da bateria.
What can I try in this difficult case?
I recently received several important messages that came to me in Outlook. I almost immediately found out about it and clicked on one of the letters. But unexpectedly for me there was an error unknown to me because of which, I can not see the text of the letter. I've repeatedly tried to check the system block for viruses, but in my problem this did not lead to anything.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Since chromebooks normally cannot run outlook how is this possible? Maybe you meant to attach this to some other more generic Lenova windows laptop perhaps?
Esta resposta foi útil?
Pontuação 0
Outlook repair software is a utility that you can use in this case talk you how to repair outlook. It is highly recommended that you backup the damaged PST first as running the tool can irreparably damage the file.
But there are outlook repair tools that could aid you like Recovery Toolbox, Stellar Phoenix, DataNumen and etc. – they are most effective. Moreover there is new generation of instruments like Outlook Online Services.
• Quit the application
• Scanpst.exe is a hidden file so make sure that the 'Show hidden files and folders' setting is enabled in the folder options
• Click Start | Search, or Find and type 'Scanpst.exe' in the Search box
• Double-click to open the file and browse to the location of your damaged archive.pst
• Click 'Start' to start the recovery process
• Try to open the file in question again. The corruption problem should not exist.
Pontuação 0
Adicionar a sua resposta
EliJuarez será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Ao todo: 387
