Ir para o conteúdo principal
Lançado em junho de 2014, identificado pelo número de modelo B051.
Wires lifted-up on BEATS SOLO 3 - I need the wiring diagramm
Hello,
On my Headphone BEATS , Solo 3 :
The soldered wires , on the jack side, have been pulled. I do not know which wire (green, blue, red, pink, pink/pink) should be soldered on which plot (8, 9, ....12) ?
Look at the picture.
A picture of a still soldered device would help me a lot !
Many Thanks
Mise à jour (08/07/2018)
now with the picture , hopefully !
Imagem
Additionnal question; is it a real or a fake ?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
hello everyone.if some of u have.ı need electronic diagram of beats solo 3 wireless headset.hugs from turkey.thanks in advance
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi @olipoul ,
Regarding whether your headset is real or fake. Does your speaker look like the one in the image below?
Here’s some links to two videos, video1 and video 2 showing the teardown of a Beats Solo 3 headset.
Here’s an image (enlargement taken from video one) showing the wiring connections. Admittedly it is not as good as your picture but hopefully you may be able to grab a better picture from the video and enlarge it even more to get a better view of the wiring.
Imagem
(click on image to enlarge for better viewing)
Hopefully it may be of some help.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Hi Jayeff, Thanks for your answer; I knew these videos. I did not want to open the rest for the moment. In any case Thanks
por
Hi Oliver, looking out your picture i think those are fake, you wrote at the title beats solo 3 and now they are made by apple, these is a picture of the real ones main board.
https://rover.ebay.com/rover/0/0/0?mpre=...
I wish you the best of luck!!
Pontuação 0
Adicionar a sua resposta
Olivier Poulat será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 44
Ao todo: 4,729
