Power port will only charge when tip of adaptor is propped up.
Power port will only charge when the tip of the adaptor is propped up. The internal port does not seem loose. Suggestions?
Esta é uma boa pergunta?
sweeney07 actually it is not soldered to the board! The C655D-S5084 use an AC DC Power Jack Plug Socket Cable . All you have to do is to replace the cable. You can get it at places like this. No soldering required! Use this guide Toshiba Satellite C655D-S5084 Cooling Fan Replacement to get to the cable
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 105
2 comentários
Thank you very much.
por sweeney07
Thanks alot!!! This is great news. I have ordered the part and the video is great!
por sweeney07
