Dryer not heating up
Dryer is not heating up. Cool down light is flashing all the time
Esta é uma boa pergunta?
mahubb810 depending on your exact model, the cooling light will normally stay on constantly during the cycle. It should begin blinking at the end of the cycle. Your dryers issue could be an issue with the moisture sensing cycle/sensor. We’ll need your exact model to see if there is an existing wiring diagram etc. to make determination about the sensor etc. as well as running a diagnostics program.
Esta resposta foi útil?
Cause 1
Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer’s heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse.
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 63
Duração total: 4,611
mahubb810 what is your dryers exact model number?
por oldturkey03
my cooling light staying on constantly dry light constantly blinking and dryer not drying (no heat) .Any body have this issue?
por Ronald s LaBrie
