Ir para o conteúdo principal
How do you turn off the external speaker?
When the music plays the sound comes through the ear phones and the speaker. How do you turn off the speaker?
Update
Thank you. Holding the toggle and menu button down did the trcik. My son is so happy. Thank you
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Good job enjoy your tunes...;-)
por
Adicionar um comentário
5 respostas
Pergunta mais útil
It usually turns of when you plug your headphones in. If that does not happen, check for debris i.e.pocket lint inside the headphone jack. You can use a wooden toothpick (just be really careful that it does not break off or pushes in to far. You can also use compressed air (again carefully) to clean it. Connect and disconnect the headphones a couple of times, since since may get a stuck contact working again. Sometimes a simple restore will take care of it too. Toggle the Hold switch on and off. Press and hold the menu and center buttons simultaneously until the Apple logo appears. Let us know if this helped and good luck to you.
Esta resposta foi útil?
Pontuação 5
What do you mean by "the sound comes through the ear phones and the speaker", I would assume that when you plug in your headphone, the music still plays through the speaker. Well in that case, there is something wrong with it. If your device is still under warranty, take it to apple for fixing or other wise try resetting the firmware by clicking restore option in itunes, hope that works.
Pontuação 0
1 comentário:
thisisgesun, this problem was resolved with a reset.
por
it worked! thank you so much. i love smart people (:
Pontuação 0
1 comentário:
you are welcome :-)
por
I checked out the same problem with others. Some people said it happened if the Ipod got wet. I can't recall if that happened to me so i put the Ipod by a vent in our home's HVAC system. Our AC ran 24/7 last week so I put it on a vent for 24 hours and voila, it did the trick!
Pontuação 0
When you call someone the speaker does not turn off so how do u turn it of if you can send me an email at * safiyahzaman@hotmail.com please if that's okay and that will be great.
Pontuação 0
Adicionar a sua resposta
Kevin C será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 13,015
