Ir para o conteúdo principal
O nome Dodge Avenger retornou em fevereiro de 2007 como um sedã do ano modelo 2008 para substituir o Dodge Stratus, cuja versão cupê havia substituído o Avenger original em 2001.
Driver seat headrest protruded
Driver seat headrest protruded from regular position.
Had to slam on brakes and the headrest popped up. So rather than looking like the passenger side it is sticking out by 3-4 inches more. Can anyone tell me how to fix this?
I'll add a photo asap
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Try pushing it down. Here’s a really poorly shot video on doing it:
https://www.youtube.com/watch?v=AQiUjxpz...
Esta resposta foi útil?
Pontuação 2
1 comentário:
Okay, there is a sensor in the headrest. So since it is already popped up, dodge can't do anything about it. It has to be replaced completely. Which costs around $200-300. So going to go am alternative route to get this fixed
por
Yes look at the back really good there is a little metal rod make sure it’s in the middle in place were it goes , with you seating in the back seat pull back and push down it will click in place look at it so you can see where and how it works not hard to do just be careful it’s plastic will break and if it’s all ready broken then go to the salvage yard and get one from there . Look at the two piston there black plastic when you pull back they clear the side and will go down for you to snap back in place hope this helps
Pontuação 0
Adicionar a sua resposta
rtaillon1 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 2,916
