Ir para o conteúdo principal
Guias de reparo, informações de desmontagem e resolução de problemas para a segunda geração do Apple iPad com rede celular 3G CDMA (Verizon), disponível com 16, 32 ou 64 GB de armazenamento. Possui processador dual core A5. Lançado em março de 2011. Identificado pelo número de modelo A1397. Os reparos exigem o uso de calor e uma alavancagem cuidadosa.
New screen not working
My ipad 2 suddenly stopped coming on. That is to say that the screen wouldn't power on or respond to the home button being pressed. When plugged into the computer, the device is recognised and if I didn't have a screen lock I'd be able to transfer data.
It was my thinking that the screen was broken and so I purchased a replacement screen for £20. It has a very sturdy and easy to fit cable, so I don't think I made any mistaked here, but the screen still does not come on.
Could this be a problem with the chipset, or perhaps by sheer bad luck did I buy a faulty replacement screen?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
It could be the screen you buy, but a long time ago I had that problem with the same device, and it was the chipset, try to clean the main board with some isopropyl alcohol, but i don´t think that´s going to help you
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Alex McElroy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 267
