Ir para o conteúdo principal
O Dell Inspiron 14R-5437 é um notebook substituto de desktop feito para durar. Com uma bateria de reposição de 6 células e um processador Intel Core i3 de quarta geração de baixo consumo de energia, o Inspiron 14R-5437 tem autonomia para funcionar por quase dez horas.
ripped one of two LCD cables while disassembling.
I was taking apart my laptop to get to the motherboard to replace it (if you can, can you also send a link to a decently cheap motherboard for this laptop that has at least an i5 CPU?) and while trying to remove what the tutorial said was the LCD cable, i broke the smaller of the two connectors. here is the link to the tutorial that i used: https://www.parts-people.com/blog/2016/0... The LCD cable is step 15. I was wondering if the smaller cable was necessary for the booting of the computer, or if I have to find a way to get the cable to work again.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Leveler02 Gaming,
In the picture you described there is only one cable which they are uninstalling , and this is the LVDS cable which sends data to the display. This would be necessary to use the built in display in the laptop.
I hope this helps,
Charlie B
Esta resposta foi útil?
Pontuação 1
2 comentários:
the other connector is hidden by his hand
por
was anything connected to that connector?
por
Adicionar a sua resposta
Leveler02 Gaming será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 11
Ao todo: 416
