Ir para o conteúdo principal
Sétima e última geração do Cadillac Fleetwood / Tração traseira / Motor V8 de 350 polegadas cúbicas (5,7 L)
Interior lights are stuck on
Originally the fuse for interior lights was missing causing none of them to work, replaced it and all of them came on and are stuck on. Door lights, roof lights, pull down mirror lights, all stuck on.
If I click the click-able lights such as above the door then that light will go off while I have it pressed down but resumes on when let go.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi @cbris ,
You may have a faulty door switch on one of the doors, i.e. permanently on.
They are usually enclosed in a rubber boot in the door frame somewhere.
There is only one wire attached to each switch and the other side connects to the chassis of the vehicle. Mostly they rust out and cause problems.
Perhaps that what blew the fuse originally, as you have to wonder why it was "missing".
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Chris Phelps será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 29
Ao todo: 659
