fw55d25f ds2 comes on with logo then off
fw55d25f ds2 comes on with logo then off after 4 seconds
Esta é uma boa pergunta?
'''++jbacon30++''' this could be a main board or a power board issues. Let us know what you have checked thus far. Start off by removing all connections from the back of your TV. Then unplug your TV. Hold the power button down for 30-60 sec. Release the power button and connect one input source only. then restart your set and see if anything has changed.
If it has not you will have to think about removing the back cover and to check out the boards. you will need a multimeter for this. Post some pictures of all of your boards and their layout so that we can see what you see. use this guide Adicionar imagens a uma pergunta já existente for that.
Esta resposta foi útil?
I am having the same issue. When the TV comes on, it says something about holding the ok button on the remote, but doesn't give enough time for this to work.
I tried the suggestions, but it keeps doing the same.
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 1,841
