Ir para o conteúdo principal
Lançado em fevereiro de 2015, o Samsung Galaxy A7 opera com o sistema operacional Android, possui uma tela Super AMOLED e um processador octa-core.
Charging issue in mobile
while charging an error is raised - battery temperature too low. and phone is not getting charged. how can the problem be fixed?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
That message is usually shown from liquid damage on the charging port or components near the charging port.
To fix this problem it requires disassembling the phone, removing corrosion from the charging port, components near it and/or replacing the charging port.
Unfortunately on this model you will need to remove the screen first (with the risk of cracking the screen) to get access to the internals of the phone.
I would recommend to take it to a phone repair shop for diagnosing the problem.
If the phone still has warranty, it's better you take it to Samsung to get it fixed under warranty.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
sachin shinde será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 26
Ao todo: 880
