20 Amp Fuse on Kohler engine
Where is the 20 amp fuse located on the TroyBilt Super Bronco, using the Kohler Courage 20 motor?
Esta é uma boa pergunta?
@grayone there are at least 2 of those. One is from the solenoid to the switch and one from the battery to the headlight. If it is the one for the starter follow the red wire from the solenoid. The fuse is an inline fuse and that way you can trace it by the wire. Same for the headlight fuse.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 70
Duração total: 2,860
