Ir para o conteúdo principal
Repair guides and support for full size headphones that encompass the entire ear, also known as circumaural headphones.
Audio jack causing problems
Isn’t this head set it is the Turtle Beach Recon 50P headset, this is the closest I could find (not in price).
So pretty much what happened was that I accidentally stepped on the edge of the jack while it was in the controller
and bent it a little.
The audio is ok if you get it in the right position but sometimes I can’t cant hear a thing. It also echos other people in the party and gives them a headache.
Just wondering should I try get it fixed it or buy a new headset. I could probably get an audio jack on amazon for cheap enough.
Only bought it a few months ago so want to get at least some use out of it.
Thanks,
R
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@ps4_ron post some images of your damage so we can see what you see. Use this guide for that Adicionar imagens a uma pergunta já existente Going by your description, I'd suggest that you replace the jack itself. Make sure that there is no fractured wire etc. Replace the jack the same way you would on a regular headset. Take a look at this guide to see how to replace an audio jack. Should be a simple replacement and keeps your headphones out of the landfill (or your junk drawer;-) and saves you some money as well.
Imagem de Skullcandy Lowrider
Guia
How to Replace the Audio Jack
Nível de dificuldade:
Moderado
30 minutes - 1 hour
Imagem de iFixit
Guia
Muito fácil
2 - 5 minutes
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Ron será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Ao todo: 136
