Ir para o conteúdo principal
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Perguntas Visualizar todos
Pergunta encerrada
how to identify and replace antenna flex cable
hi,
i read on the answers on your website and got to know that NO SERVICE problem is caused due to damage to antenna flex cable. please tell me how to identify, buy and replace the antenna flex cable. also if u could tell me about which is the most reliable dealer for buying it in india. also should i buy the original apple manufactured flex cable or from any other source.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
Well, lets start off by saying good that you did your research on the item. And if my answer is correct, please let me know. When you open your iPhone 3g(www.ifixit.com will show you how) and pull off you your entice display enclosure, you will see the Cable dock flex cable. Disconnect this from your logic board and make sure to unscrew the necessary screw. What you have is a combination of three part that you have just taken out because they are all connected. First was the dock connector flex cable with the left speaker attached. Second is the sound buzzer/bottom speaker en-closer. It's all black and not that big. On the bottom of that, which is the third part (as well as the part you are looking for)if your antenna flew cable. This is the part you want to replace. Now if you think if you can just buy this item and replace it, your right but wrong. There is metal prong that is connect from the antenna flex cable to the buzzer. The buzzer is also connect to the dock flex cable. In simple terms, you want to but the piece already assembled so you will not have to deal with the hassle like i did (talking from personal experience). Now where can you buy this, thus far, ifixit.com has not been able to accommodate for this item, but eBay has. Since you are in India, i think eBay would work best for you. I also think you should purchase from somewhere in Thailand or Tokyo. there items are usual cheaper and also usually have free shipping. Hope this has been of help.
Esta resposta foi útil?
Pontuação 1
see the teardown guide for iPhone 3G, step 18 for the location of the antenna flex, or the repair guide step 17 - it's on the back of the dock connector assembly
and for reference, look at this other picture of all the 3G parts - you can see a small picture of the antenna there
Pontuação 1
Hello everyone,
We are jacktelecomfrom Shenzhen China.
We are specialized in all parts of blackberry,iphone and HTC.
We have the latest new products in stock now,
and we have considerable price advantages.
If you are intersted,pls contact at:jackteelcom188@gmail.com
Welcome to our website:www.jacktele.com
Here is a simple list of products:
iphone 3g original digitizer
iphone 3g copy digitizer
iphone 3g digitizer assembly
iphone 3g lcd with digitizer
iphone 3g lcd(original)
iPhone 3g Lens/glass
iphone 3g original box with accessories
iphone 3g high copy box with accessories
iphone 4g oem touch panel(white and black)
iphone 4g high copy touch panel(white and black)
iphone 4g oem lcd
iphone 4g oem bezel
iphone 4g oem chassis
iphone 4g lcd with digitizer
iphone 4g high copy digitizer assembly
iphone 4g oem digitizer assembly
iphone 3gs original touch panel
iphone 3gs copy touch panel
iphone 3gs lcd
iphone 3gs digitizer assembly
iphone 3gs lcd with digitizer
iphone 3gs back cover(copy,with inner structure)
iphone 3gs back cover with bezel
kingly regards
John
Email:Jacktelecom188@gmail.com
MSN: jacktelecom188@hotmail.com
Pontuação -1
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 28,228
