Ir para o conteúdo principal
A HP Officejet Pro 8600 Plus é identificável pelo seu número de modelo: N911g. Lançada em 2011, a impressora pode ser identificada pelo seu acabamento marrom e painel de controle touchscreen.
HP printer not accepting ink
My printer says the black ink is bad, bought a new one and still not working says ink is not original which it is so I bought a new ink cartidge and the same stuff, ink is not good, did Drs scanner and no help, what can I do.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
7 respostas
Solução escolhida
Are you on instant ink programme.? If so phone UP and they will send you new cartridges. If not try connecting printer with USB cable, not Wi-Fi , switch off, remove both cartridges switch back on and reboot using initial start up procedure.
Esta resposta foi útil?
Pontuação 1
Why are the Ink Cartridges not detected?
1. Printer Internal Memory Needs Resetting
2. Metal Contacts require Cleaning
3. Protective Tape or strips aren't removed
4. Disable HP Cartridge protection
5. Wrong / malfunctioned ink cartridges
6. Improper Cartridge Installation
Guided Steps of 123 hp printer setup ******Support And Installation Of Your Hp Printer. Wireless Printer, Android Printer, IOS Printer, Drivers Setup US.  Get HP Printer Support.
Pontuação 1
Took my Printer to fix, thanks.
Pontuação 0
You said that you took it to be fixed, it would be helpful to those reading this later, if you could share what they found, what had to be fixed, etc.
Pontuação 0
Is your hp printer not accepting the ink due to which you are unable to print? Then you do not have to have to get puzzled as you have landed in the right place. This answer will fix your issue in simple steps without wasting any time.
Why Does This Happen?
There can be many reasons for your HP printers do not accept the Ink. some of the reasons are as follows:
  • Toner is not compatible.
  • The cartridge is locked automatically.
  • Some changes in the settings of the printer.
And there can be many other reasons that may lead to the printer not accepting the ink. Let us now tell you how to fix the issue.
Getting The Printer Glitches Fixed!
To fix this issue the user may follow the steps below:
  1. Check if toner is fixed properly.
  2. From the settings of the printer, unlock the cartridge in case it has been locked.
  3. In case the cartridge is not detected then you can take the cartridge out and try a new one. Make sure that you do not have the local cartridge.
Pontuação 0
HP printer help and support
Need help with your HP printer? Well, now you can get 24*7 support of HP printer technicians who are here to assist and troubleshoot any issue related to the HP printers. HP printer help you find a quick solution for all models of HP printer. Our experts use top-class diagnostic tools to get through the issue.
Pontuação 0
4 comentários:
Actually, what you have posted is a lie, something it seems to be contagious nowadays. My question is VERY SIMPLE, but NONE of your pages upon pages and clicks upon clicks seems to want to answer my question...MY QUESTION IIS "WHY ON THE PAGE "SEARCH HP HELP" NO LONGER SHOWS THE INK LEVEL. The ink level ICON is still there but it's grayed out. WHY?????
por
It looks as if the only thing PH is geared to is selling merchandise. How sad is that?
por
Hi,
If you've already tried multiple genuine black cartridges and the printer still reports them as bad or non-original, the issue is likely with the printer's cartridge contacts or printhead rather than the ink itself. Try cleaning the contacts, reinstalling the cartridge, and performing a printer reset. If the error continues, the printhead may need cleaning or replacement.
Pontuação 0
Adicionar a sua resposta
elgranpiro será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 40
Ao todo: 4,147
