Ir para o conteúdo principal
Device repair and information for the Dell Inspiron 14 line of computers.
Why my Laptop doesn't respond to charger?
My charger has a indicator that it is working but the time i plug it in my laptop the light turn off and doesn't charge.
Update (05/21/2018)
Thanks for te respond @oldturkey03 my laptop was DELL INSPIRON 14 3000 series
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
@kiehlashleigh this could be a bad AC adapter, a bad connector, a bad battery or a board level failure. 'd start with measuring the output of the charger and see if that is supplying the right voltage. If so, I'd check the DC-in connector to make sure it is still properly connected etc,. If you can give us the exact model number of your computer, I am sure we can find more information that might be helpful to resolve your issues.
Update (05/21/2018)
@kiehlashleigh you can download the service manual for your computer from here. It will help you with getting to the DC in port etc.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Kiehl Ash será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 244
