Why is my screen turning pink?
My screen has developed a pink hue. What is the cause of this problem and how do I fix it?
Esta pergunta é pertinente?
The Asus Q551L is a 2 in 1 device released in 2014 by Windows. The screen is 15.6" and the device comes with a 2 GHz Intel Core i7 processor.
Hi @lawanddisorder5 ,
Try connecting an external monitor to the laptop and check what its' display is like.
If it is OK then you have a problem with either the video cable to the display panel (loose connection either end, motherboard or panel, or as is more likely the display panel in the laptop is faulty and it needs to be replaced.
Reputação: 1
Video cable is more likely than the whole display, motherboard, etc. Test as jayeff suggests.
The video cable has to go through the hinge and after a while gets damaged from flexing. First thing to try is readjusting the cable slightly to give more slack at the hinge point. May mitigate the pink screen problem.
Últimas 24 horas: 6
Últimos 7 dias: 40
Últimos 30 dias: 158
Duração total: 3,345
Mine is starting to do the same thing. I saw a post that said to remove the battery and then reinstall it. I can’t tell you if this will work or not, because I don’t know how. Please let me know how you fixed yours. Thanks.
por cathynnc
