Ir para o conteúdo principal
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154 Perguntas Visualizar todos
Slow Charging, 15% on 2 hours
Hi,
Im having an issue with an iPad 3.
- Already replace the dock connector, but the battery charges real slow, about 15% in 2 hours. Rested multiple flex connectors, issue persist.
Any one had encountered this issue?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
It's probably battery related. However, before replacing the battery, try a known-good original iPad charger and Lightning cable to eliminate that as a potential source of problems.
If you have confirmed that the charger and cable are good, the try to replace the battery, following this guide, to see if that solves the problem. Otherwise, it could be a logic board/charge circuit issue.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Robert G será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 138
