Ir para o conteúdo principal
Guides and repair information for Shark vacuums.
298 Perguntas Visualizar todos
Why is this filter spinning around in my Shark vacuum?
Hi,
The filter spilled out of my canister when I was dumping out the dust cup and I put it back in. But now it spins wildly in the canister making the whole vacuum vibrate. It doesn't seem like it's sucking as much now and also making high-pitch squeaks due to air being forced.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Here is a link to the ifixit Shark Vacuum guides.
Hopefully your model is listed (you didn't specify) as most guides show how to remove and reinstall the filters.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thanks, I'll check it out.
I have a Shark Apex Powered Lift-Away.
por
I figured it out. I had the filter in the wrong part of the dust cup housing.
Rookie mistake ;)
por
Adicionar a sua resposta
Robbo4473 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 119
