Ir para o conteúdo principal
This Asus laptop is a 2-in-1 touchscreen laptop. It can be identified by its model number: Q504UA-BHI5T13.
11 Perguntas Visualizar todos
Can I upgrade my Intel i5 7200u to a Intel i7 7500u?
I have this computer and it often has trouble fitting my needs. Getting a new computer is out of the question, but I want to upgrade. The socket of the two processors is the same, BGA1356. Before I commit to buying the i7, I would like to know if the BIOS and motherboard can even run it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi Doc Yellow
The processor is soldered into the mainboard
Asus Q504UA-BHI5T13 Heat Sink Replacement
it is designed not to be user replacement.....
Esta resposta foi útil?
Pontuação 1
2 comentários:
I believe you, I just don't see how this answered that. Also, in step 8, if you zoom in, the processor looks very removable, it even has an arrow.
por
Hi Doc Yellow
BGA1356 is soldered directly to the mainboard
those chips dun come cheap either!
https://www.aliexpress.com/item/100-New-...
the arrow is meant for the alignment of the mainboard to the correct pin contact orientation.
Without proper equipment / tools / skills,
por
Adicionar a sua resposta
Doc Yellow será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 4,055
