Introdução
This guide will show you how to remove the heat sink from the Asus Q504UA-BHI5T13.
The heat sink is a vital part of a laptop that ensures proper CPU cooling. In cases of heat sink fan damage, the part will need to be replaced. It is recommended to have some experience with electronics before attempting this guide.
Note:
When removing the screws attached to the heat sink, follow the proper order, provided by the guide at that step, to avoid damage to the heat sink. Further, handle the heat sink with care; the copper coils may be easy to damage.
Before attempting this guide, power down the device and remove all external peripherals and charging cords.
O que você precisa
Once the back cover is removed, have the laptop facing upside down with the hinges facing nearest to you.
Uma outra pessoa concluiu este guia.
