Ir para o conteúdo principal
Asus ZenFone 2 (ZE551ML) is an Android smartphone manufactured by ASUS released March 2015.
Phone is water damaged. How to fix it?
Hello,
I dropped my phone in the water accidentally. I had removed the back panel , cover and battery connector to main board. I did notice some water on main board and battery which I soaked with soaking paper.
I kept it for some time and then connected the battery after which it started normally. After some time screen was acting weird, flickering, black lines from a side.
The black patch is increasing slowly while screen is still flickering and off colored.
I had gone to service center and they diagnosed it with bad screen and main board.
I was wondering if it was bad main board then why is my device getting on ?( I can see my home page and wallpaper) I am able to charge the device all though I know that is a bad idea. How can a main board be damaged if my phone is turning on?
Can anybody help ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Electronics Water Damage
Follow that link on how to clean it.
It is possible the board is damaged. But only certain parts causing the screen being funny among other issues. Clean it and try it. If the screen is still broken, the screen also got damaged and will need to be replaced.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
BDB será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 715
