Ir para o conteúdo principal
Repair information for non-Apple computer keyboards.
capslock key is unresponsive
so i'm currently using a red dragon mechanical keyboard k552-r, and the issue i'm having is my capslock led toggles on and off as normal but the key itself is unresponsive. So, to sum it up: I can't capitalize anything less I press shift. I've tried multiple keyboards and i get the same problem so i'm sure it isn't the keyboard. Is there anything you guys can help me with? I apologize in advance if this question has been asked. P.S the caps key sometimes works, and i'm running windows 10.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
i downloaded, "Reimage Repair" and unfortunately, i had to pay, but nonetheless it fixed the problem as well as others i was meaning to fix. thank you guys.
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
Hi Dizzy,
Try enabling the on screen keyboard and toggling the caps lock there. Does that work?
Do you by chance have any third party software which may use the caps-lock key as the trigger?
You can also try resetting the caps lock by following these steps.
Pontuação 1
Hey bud, how long has it been playing up? Is it a new install of windows 10? Is it 32 or 64 bit? Has something changed recently? Like hardware/software? I would suggest uninstall and reinstall drivers from manufacturers website and try compatibility mode. Then post back with the results.
Pontuação 0
Adicionar a sua resposta
Dizzy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 32
Ao todo: 2,960
