Ir para o conteúdo principal
Mouse Trackball Sem Fio M570. Lançado em 2010.
How to disassemble trackball
I need to clean the trackball rollers inside the mouse, how do i dissasemble
Esta é uma boa pergunta?
Pontuação 2
2 comentários
Thanks for the quick response, that was extremely helpful.
por
I examined my bearings under a magnifier and saw fine pet hair and what may be skin cell crud. Scrubbed the bearings with toothbrush and alcohol. Bearings didn't roll smooth until the alcohol dried. If I did it again, I would try with a dry toothbrush first.
por
Adicionar um comentário
2 respostas
Solução escolhida
Here's how to tear it down:
Substituição dos interruptores do trackball sem fio Logitech M570
Esta resposta foi útil?
Pontuação 9
5 comentários:
Glad I could help.
por
Thanks, from me too. I just needed to clean the dust out of mine, so it didn't take as long as the instructions indicated. I guess they're actually for replacing the switches but the disassembly/reassembly is the same. MUCH appreciated!
por
The battery screw got me! Thanks a bunch!
por
This is perfect. This model is perfect for my hand and since it was superseded by a new one which is a bit too large for me I have to to take extra care of my old trackballs.
por
Thanks for this, great to find out where all the screws are hidden. Just needed a bit of a clean to get the switches working properly again.
por
If all you’re trying to do is clean under the trackball, turn it over and push on it through the hole. It pops out.
Pontuação 5
Adicionar a sua resposta
Gassan Rihany será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 6,088
