Ir para o conteúdo principal
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 Perguntas Visualizar todos
I replaced the trackpad have press hard for touch
I replaced the trackpad. everything works fine except the touch. Have to press very hard to use the touch
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
It sounds like you over tightened the click screw. Go back to the MacBook Air 13" Mid 2013 Trackpad Replacement guide and review step 10.
Esta resposta foi útil?
Pontuação 2
Richard,
Inside the macbook air where you replaced the trackpad there is a screw (bottom-middle of this image
), you may need to adjust this to change click pressure.
Hope this helps,
Charlie
Pontuação 1
1 comentário:
When I initially replaced the trackpad I never touched the adjustment screw.
Opened up the computer and made a 1/4 turn clockwise on the adjustment screw and now everything is as it should be. Thank you.
por
Adicionar a sua resposta
richard será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 59
