Help - Error code (E?cL) not listed in manual
I have an error code that looks like EcL but the top horizontal line on the E is missing. The washer lets me toggle through different wash modes I.e normal, heavy duty, etc..., but whenever I press start or try to add an extra rinse or choose the self cleaning option it toggles back and forth between the error code. I have tried unplugging the washer, holding the control lock, and doing the maintance recommended in the manual. Nothing has worked or made any changes.
The washer model is 796.44162
I have also verified that the LEDs illuminating the digits for letters 'c' and 'L' in the error code work fully, but I am unable to verify if the first digit for the 'E'? Fully works.
Thanks for your help,
Miguel
Esta é uma boa pergunta?
4 comentários
Can you see the picture? Also I forgot to mention before this model of washing machine does not have a sensor to detect if it's clean or dirty so their is no error messages to run a clean cycle.
por OffGridMiguel
Hello, they could solve the problem with your washing machine, I still have the same problem
por Walter Ugalde
@Walter Ugalde same washer and displays the E cl as well? What is your washers COMPLETE serial number?
por oldturkey03
@oldturkey03
Kenmore Elite Font-Loading Automatic Washer
Model 796.41982.410
Serial No. 805KWZH26021
W/O: 81F006P
por Walter Ugalde
