Ir para o conteúdo principal
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
Model 917 Differential Problem
Tractor, YTS4000, 24hp 6 speed manual-- has difficulty turning. To me it seems the differential is locked as the front wheels continue to want to plow forward while turning. (This is not a "steering" problem as the front wheels turn fine) What I see: This winter when using the snow blower as I attempted to turn right, the right rear wheel was spinning!
Esta é uma boa pergunta?
Pontuação 0
1 comentário
You are 100% correct. It thinks it is a drag-racer with 'posi-track' !
por
Adicionar um comentário
2 respostas
Solução escolhida
@tlien this mower uses a transaxle. See if you can find a tag or manufacturers number on it. If there is none check the attached image for an ID and let us know if there is a match.
This is not an answer but the only way to post an image. I shall delete it once I have clarification from the OP No reason to downvote it yet ;-)
Esta resposta foi útil?
Pontuação 1
1 comentário:
Need to replace the two Drive belts on a 42-in craftsman motor
por
Pergunta mais útil
If you're a 'shade-tree-mechanic', you can save a few bucks by removing the unit, and take it to the shop for repair. Or, fix it yourself. These machines were not known for their longevity, plus differentials are expen$ive, so I would make it a D.I.Y. project.
Pontuação 1
Adicionar a sua resposta
Terrence Lien será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 13
Ao todo: 432
