Ir para o conteúdo principal
Também conhecido como Moto G3—um smartphone Android lançado pela Motorola em julho de 2015. Ele serve como uma alternativa econômica aos aparelhos premium da Motorola. Modelo XT1540 nos EUA, com variantes dual-sim e "Turbo Edition" vendidas em outras regiões.
Wrong touch screen replacement
Hi
I changed the touch screen of my moto G3 and for my very stupid mistake i've switched the power on button before to connect the new touch screen!
The phone started with vibration and very hot! it was not possible to stop it in any way.
After the full battery drain i tryed to connect the touch but it doesn't charge the battery and no life.Can someone please tell me if I have some possibility to restart with the phone? I tried many times the hard reset power plus vol- but nothing happens.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
The battery is completly drained 0 volt.
The replacement touch screen was new and tested.
I tryed to connect the phone with charger and battery out but nothing happens.
por
Adicionar um comentário
1 resposta
So, you swapped the screen out and before you could connect the digitizer cable you turned it on by accident, correct?
It sounds like some shorted, because of the heat. Is the old broken screen still intact? If so, can you try to reinstall it and see if it works. If it does, you have a bad replacement part.
Esta resposta foi útil?
Pontuação 0
4 comentários:
ThankYou for answer
in the previous post i've forgotten to said that the new touch screen was tested and it was ok.
after i switched off the phone and disconnected the touch just for finishing with the stikers around the corners .After that it happened to me.
Any way i tryed also to disconnect the battery and plug the usb cable without battery, the same. Do You thing that with a new touch screen will be fine?
por
It's still possible that the screen went bad. I dont like to rule anything out, because I've seen a lot of strange things over the years. I would pull the battery like you said and let it sit for a while. Then reconnect the battery and see if you get any life out of the screen.
por
So You thing the best will be to buy a new touch screen?
por
If disconnecting the battery and letting it sit for a while then retesting doesnt work, then yes. However, something could have fried during the repair, so make sure to purchase another screen from a company with a good return policy.
por
Adicionar a sua resposta
Giovanni será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 14
Ao todo: 365
