Ir para o conteúdo principal
Touch is not working. Missing a voltage?
Hello all,
More of a technical question... I have an iPhone 6 with no touch. Before lifting cumulus I was poking around for voltages and am missing PP5V1_GRAPE_VDDH. There is no short to ground on that line.
I pulled U1501 and replaced it with one I had on a doaner board that might have been bad. I lost all image on the screen but had backlight after that.
Retracing my steps, I reballed the original U1501 an stuck it back on and the phone is back to how it was.
Should I order and install a new U1501 or is there something else you would advise me to check first?
Thanks all and happy repairing!
Joseph
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
did you try meson to see if it could be an issue
Esta resposta foi útil?
Pontuação 2
28 comentários:
Honestly no I have not. Before pulling it off I thought I would check voltages going to the two.
If it were an ip6+ they for sure first thing would be an M1 jumper. But in this case, no stress on the board seems to make any difference in it working, so I was leaning away from classic touch diseases (also being a 6 not a 6 plus) are there some inputs I should test out for menson? Or what would you recommend I do to it?
por
cumulus and meson have connected lines like CUMULUS_TO_MESON_VSTM_OUT_N, CUMULUS_TO_MESON_VSTM_OUT_P, CUMULUS_TO_SAGE_BOOST_CLK_EN, TOUCH_I2C_SCL, TOUCH_I2C_SDA
por
also did you check resistance on j2401
por
I didn't check resistances on j2401, somehow that passed my mind .... Surprised. That could easily tell me what it might be.
Is it normal for U1501 to have 2 of the 3 power outputs OK and the third dead? That's my primary thought on this one at the moment. I don't have the schematics here with me at home, butbinkimda thought that they would all be present, or none.
por
I will definitely check those lines though on Monday
por
Exibir mais 23 comentários
Adicionar a sua resposta
Joseph Hughes será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 566
