I am getting AF message on Maytag Bravos Dryer
I ALWAYS clean out the filter on the machine. I also vacuum or brush the vent area in the machine at least every other month. I have someone in to clean the vent every year yet I have gotten this message twice in the last 2 weeks and the machine is only 13 months old. What is my next step?
Update (04/29/2018)
Thank you so much for the quick response. My dryer is a Maytag Bravos XL MEDB835DW3 and is 14 months old.
Esta é uma boa pergunta?
7 comentários
No response to the 4/29/2018 update answer I sent.
por mom1216
It was helpful ; however, as noted in your repsonse, I sent the model # of the dryer and never received an answer back as to where and what sensor is at fault. I also figured out that the AF flashes only when I move the dryer to "Bedding". AF does not show up on regular dry.
por mom1216
What is f1 stand for
por Edward
Same issue. I took the entire lint test out to clean and I am concerned I wired it wrong
por ifoo134
I have a two year old, purchased new from Lowes’, Bravos XL MCT MEDB835DW4 dryer. The AF error code showed up about 1 year into ownership. It doesn’t impact the heat or drying clothes. After reading a lot of forums I went ahead and replaced WP8577274 Dryer Thermistor & WP3392519 Thermal Fuse thinking it would solve the AF problem. It did NOT. I clean the lint trap, vacuum it annually inside the unit and I have a drill attachment that I run out my vent line with minimal debris ever captured. My house was built in 2019 and is less than 2 years old, so current code on exhaust, corners, etc. Anyone have any other ideas on AF code generation? I did check the thermistor and fuse I pulled out w/ my Ohm meter and my thermistor held~11 and my fuse was 0.
por Jeremy Gall
Exibir mais 2 comentários
