Unfortunately….the TV Screen is bad. The LEDs are at fault.. It is nearly impossible to remove screen cover to replace the LEDs in any TV. When under warranty…we will receive a new panel (screen, once called the picture tube) and replace. Take boards out of bad TV and install into new panel. A new panel is as much as the TV $. I have seen many TVs with this problem, and is common to all sets now. Thanks for asking, Matt of Martins TV Repair.
I have repaired many of these. Unfortunately the LEDs are not operating correctly. It may be the LED board. But truly the LEDs are flickering because of a faulty LED. These units can have approxitimately 40 + LEDs. If one goes out….they all go. The only real poosible repair is to replace the entire panel (What you actually watch is the panel). You may have seen repair on line, replacing LED strips…that may be fine. This is very time consuming and can be a complete waste of time. Under warranty, ( year old or less) a new panel is sent. We remove the boards from your now TV, and place them into the new panel. I would consider shopping for a new set. Thanks for asking, Matt of Martins TV repair.
Another thing you want to try, in TVs with this issue. LVDS cables may need cleaning. These are the TAPE (CABLE) RIBBON you see to and from power supply to main board. The other RIBBON CABLE to the T-con board or the TV its self. Unclip these carefully and slide out. With a can of electronic cleaner spray a chamois stick. Clean the contacts at the end of the RIBBON CABLE (TAPE), and then the board contact its self as well. Thanks for asking Matt of Martins TV Repair.
Isn't this NEW TV still under warranty ?
por Tom Shafer
I've had mine (55') for 16 months...
por stephensnider10
I've noticed that if I put it on low power in picture mode it drastically reduces the flashing does this help in finding a solution?
por stephensnider10
stephensnider10 since it changes with the change in picture mode it sounds like a power board/ backlight issue. Most likely condidates is the backlight array.
por oldturkey03
TCL sucks! Had this same issue within my warranty period. They had me do a power reset, fixed the problem for 2-3 months. It started again, but now I'm out of warranty period, and they will do nothing. The customer service agent told me this was a common problem, but only gave me a bandaid, not a fix to the problem, to get me out of warranty so they didn't have to replace my tv. I will never purchase another tcl
por John Bishop
Mostrar mais 27 comentários
