Ir para o conteúdo principal
An Amazon tablet released in 2014 featuring a 7 inch HD color touchscreen display.
33 Perguntas Visualizar todos
Page color changed accidentally
When using my of I clicked something & my screen turned color. Help
I cannot change it back, everything has a yellowish orange tinge to it.?
Esta é uma boa pergunta?
Pontuação 8
Adicionar um comentário
4 respostas
Pergunta mais útil
Had this same issue with my daughter’s tablet. When you swipe down from the top of the screen to bring down the settings menu or to switch profiles, etc. In between the icons for Airplane mode and Low Battery mode, there is a picture of someone laying in bed. If this is highlighted, simply press this and it will turn off “Night Mode” and get rid of the yellow/orange color on the screen!
Esta resposta foi útil?
Pontuação 14
17 comentários:
OMG! Thank you! I was checking all of my settings, the blue light mode, everything and couldn't figure it out. This was it. Thank you for explaining it and helping me find the issue. I think I love you........
por
Thank you! the yellow screen was driving me crazy.
por
thank you so much
por
Your Comment Saved Me Too , Thanks a bunch!!!!
por
Thank you so much. I was in panic mode
por
Exibir mais 12 comentários
Make sure that there is no "nightlight" screen function/setting.
On most devices there is a color function to make the screen warmer, and easier to look at for longer periods of time.
Pontuação 3
1 comentário:
I agree with Blaiden. Follow the instructions on this link to turn off "Blue Shade":
https://www.amazon.com/gp/help/customer/...
por
Did not work on my kindle fire. Orange color no matter what setting.
Pontuação 2
On Windows 10, you can check if color filters are turned on by pressing the Windows key + Ctrl + C. If color filters are turned on, you can turn them off by pressing the same key combination again.
If you have a graphics card from Nvidia, AMD or Intel, you may also want to check the color settings in your graphics card control panel.
Pontuação 0
Adicionar a sua resposta
bofski0 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 133
Duração total: 24,310
