Ir para o conteúdo principal
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Perguntas Visualizar todos
After getting my screen replaced, my phone screen is risen too much
My phone screen got replaced today and the screen isn’t flat when you look at it from the side. Is there any way I could just push the screen in without cracking it again?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
yes here i dont know i this is too technical or not but heres what i found: screen-size: 5.5inch (139.7mm)
Resolution:1080 x 1920.
depth:7.3mm (0.29inch)
height:158.2mm (6.23inch)
weight:188g (6.63oz)
width:77.9mm (3.07inch)
Esta resposta foi útil?
Pontuação 0
I don't think you can push it in without breaking it again. What I would do is go back to where you got the screen fixed, tell them the problem and see if they can fix it. But if you can show me a pic of it from the side I might be able to help you more.
Pontuação 0
3 comentários:
I’m sorry I can’t post a picture but I may just be paranoid and think my phone screen is raised too much. Do you know where I could find the measurements for an iPhone?
por
HI,
I have the same problem after replaced my screen. The screen doesn't work properly so I ordered replacement screen from iFixit. After I installed iFixit's screen, it also risen too much and I had to press hard on the screen to activate 3D Touch. Do you think the mechanist broke my phone?
por
No. Your phone is fine. Your screen is aftermarket not Original.
por
It's most likely a aftermarket part that is why it is a little thicker than the orignal.
Pontuação 0
Adicionar a sua resposta
BTSGarbage será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 33
Duração total: 470
